Rockwell Hardness Tester Questions
I hope you have the time to answer a couple questions for me regarding a used 3R Rockwell Hardness Tester I purchased. First it is missing the test plate or anvil part you lay the material on, and not sure which one I need for testing blade materials . Also I laid it down on its side on a pile of clothes to haul home and when I stood it back up some small rod fell out threaded on one end and a hook bent on the other end, I am not even sure if it belongs to this tester, I don't see a place for it. Do you know where I can find the test plate / anvil I need? And what that rod is ? Thank you very much for your time. Sincerely Dennis
Not really sure where to post this.
The anvil and test block are different items but you'll want the flat anvil. Looks like a disc with a post on the bottom that drops into the elevation screw. A test block is steel of certified hardness used to verify/calibrate your tester. I'm not sure about the threaded rod with hook I have a different model, sorry.
Thank you. Yea that threaded rod with a hook makes me think it was some sort of weight hanging dohickey, but I don't know. I figure someone has one like it might see my post and let me know. If I could find a schematic on it I would be set. Thanks again
A three second search for "3R Hardness Tester Parts Diagram" got a couple hundred of these:
R0b57a2bca174a41ea5471f4f3ceab65d
R7ebe852260214bd2f9ae2294b4efc4db
