Roger Bergh Dagger
This was the first high end knife I ever got....started me down a great road.Hopefully I'll get the pic posted,not sure if I have enough computer skills to do it.
Thanks Matt!Seems I'm getting it now.....just got to see about making it bigger.I appreciate the help,and the welcome .Glad to be here!
Welcome to the forums :)
If you got the red X its either the link to your picture isn't quite right or its your host.
I just tried to go look at the pic and it said I needed to login. Might not allow hyperlinking.Only thing I saw wrong in the first post was the bracket on the first was backward.
your address seesm awfully long though. Try going into your hosting opening the picture and right clicking on it. Under properties, it will list an address, copy and paste this into your post and put the [IMG]..... tags around it.
You can also use the edit button in your posts to go back and fix stuff so you don't have to have 25 posts that don't work right :D
Thanks Roger.I guess i should tell a litle about it.THe blade is a multibar damascus/wrought iron(wrought iron is the center).Handle is made from Ice-age(I guess that means real old) reindeer bone with a palm wood spacer.Sheath was made by Roger Bergh as well.THanks for looking,and thanks again,Roger for helpin me out.
