- Sep 19, 2001
I've had the Cara for a while, and the edge holding has been really nice. It finally got to the point where a minute stropping on the CrO wasn't getting it back to shaving, so I worked it on the 2.5 micron silicon carbide paste on watercolor paper (got the idea from Tai Goo) Well, after twenty-something passes, there was a burr or roll in the last half inch. It was very smooth and even, but the edge didn't have any chips or nicks to begin with. I cleaned it off with a fine Spyderco rod held in hand, and then stropped the blade to clean shaving arm hair. This is a combo edge Byrd, which means the edge bevel is chisel ground, and I did most of the work on one side. The rolling was not really a problem, as it sharpened quickly nonetheless, and did not happen in use-but I thought it was a bit strange how easily it formed. The blade doesn't feel 'crisp' on the stone like S30V, M2, or D2, nor is it 'gummy' like some ATS-34 and softer AUS blades I have sharpened. In those cases I can get a somewhat ragged wire that I have to clean off gently, or a very floppy one that takes multiple passes on alternating sides to remove.
