fitzo said:I am considering buying a 4" rotary table for my micromill. Does anyone have any comments on the $125-250 range of tables available from the likes of Grizzly or Little Machine Shop?
Any info/advice would be most appreciated. Thanks.
fitzo said:Thanks, Michael. One of the things I'm wondering about is that LMS offers the PhaseII and another that looks identical except for the nameplate with a $40 price difference.
One tip I did pick up at mini-lathe.com was to keep an eye on dial size, as the Sherline he tested had an adjuster wheel on it that dipped below the base, meaning it had to be set up off the end of the table so the handle would turn.
It's good to know you are happy with the PhaseII. I will give LMS a call and ask what the difference between the 2 is. Thank you, sir!
fitzo said:Not at all, Mike. Didn't give it the slightest thought.I need people to share their insights on this. The only justification I've ever needed to buy something is "toy". I may have grown "out", but not "up"!
I need either a 4-jaw chuck and a milling attacment for the lathe or a rotary table. I figured I could mount an odd-shaped piece easier in the rotary table and use the mill head than use the lathe to make a terraced section on said odd shape.
adammichael said:I have a milling attachment for a taig mini mill that you could probably sweet talk me out of real cheap if you interested.
