- Sep 15, 2002
A bit of advice requested from the experienced "convex edgers" on the forum.
I just read a knife review where the reviewer used 3/4 inch manila rope to test the knife's edge for different sharpening methods. He started with a worn 400 grit belt + Jeweler rouge strop (hairp popping edge lasted only four cuts). Next he tried a new 320 grit belt (7 cuts). And finally a worn 150 grit belt (50 cuts and it still could cut arm hair). I take it that the worn 150 grit belt produced the best working edge for this example because of the grain of the "saw tooth" edge it created.
Many on the Forum have suggested the 600+ grit sandpaper on mousepad/belt followed by stropping with rouge or chromium oxide stuff.
In comparing the 600 grit + rouge strop "fine" edge to the 150 or so grit "rough" edge for the following two khukuri/karda uses, which edge is better for a) effectiveness of the edge for the job and b) durability of the edge during repeated use? (i.e. which edge is better for which job and why?)
Job 1 - The food chopping, game gutting and skinning, and light chores (cutting cloth, string, rope, etc.) of a camping knife?
Job 2- The woodchopping and brush clearing of a machete / axe?
Many thanks in advance for the wisdom!
