Almost every guy who forges will have an angle grinder around for rough grinding to remove scale, etc. It can be problematic at first, cuz you can gouge your steel easily and quickly ruin a potential blade. After a short while, though, you will get your technique down and have a lighter, more accurate touch. If mine broke today, I'd be at Home Depot within the hour.
A must for cleanup in welding operations, too.
Another thing you can do, too, is soak the bladestock in vinegar overnight to remove the oxide portion of the millscale. Helps a bit.
I got so tired of removing that .010" or so on each side of the stock that I eventually bought a surface grinder. Remember with S30V, it comes oversized, and is specifically meant to be surfaced down to finished dimension in order to get through the crap layer on the outside. Failure to remove all of it can result in a pitted surface. In other words, if you bought 3/16" stock, strip the surface off until it's actually .187" or less thick.
I've read of some guys doing most of the blade grinding with an angle grinder, then finishing with files, then paper. I'm way too lazy for that.
