Rough Riders received, initial impressions
As I mentioned in another thread, I've become curious about some of the Rough Rider and other China made knives that are produced as China made knives and not American brands that sold out. I recently took the plunge and got the two knives pictured in the link below. (Hopefully it works.)
http://pg.photos.yahoo.com/ph/amos....detail?.dir=/8c4ere2&.dnm=bf80re2.jpg&.src=ph
The muskrat is imitation abalone while the barlow is tortise.
Both knives have a fit and finish that, I hate to say it, runs neck and neck with my current productin Case yellow handles. On both the Case knives and the Rough Riders there are some very tiny lines of space between the liners and the backsprings here and there. I'm talking pretty minimal here, but there are no clearly superior fits between the two product lines, at least on my examples.
Truth be told, on my Cases the base of the blades where they rest against the backsrings are overly polished and rounded. The Rough Riders tend to be more squared off. Remember, I'm only comparing a couple of Rough Riders with a three or four Case Yellow Handles. Overall the bolsters then to be rounder and smoother in design avoiding sharp corners on the RRs. On both Riders the bolsters have a single line across.
Both Rough Riders have excellent scale to bolster and scale to lliner fit. The nail nicks are of the matchstrike variety and add a nice touch. Looking end on from either end of either knife, the fit and finish looks good. Both examples are quite attractive and would look good in a dressed up environment.
By way of comparison, I found that where none of my Case YH CV knives (current, 2003 - 2006 production) have any hesitation at the halfway point, both Rough Riders have half-stops, though not with any clear snap into place. They are more of a temporary drop in resistance, slow down to get on/off the bus kind of stop and cary between knives and even a little between blades. Still, they have it, and the Cases don't.
Both knives also have some heft to them. Just by feel, the barlow feels a tiny bit heavier than a delrin stocked Boker barlow I have. Not significantly so, just a tiny, barely perceptable so. The muskrat spreads the weight out and doesn't feel offensively heavy in the hand. Neither does the barlow for that matter. The muskrat is comfortable in the hand in fact. It is in the pocket that I notice them. For a fair comparison, I'm used to carrying the Case YH Sodbuster Jr that I've yammered so much about the carrying qualities of and its new companion, perhaps competitor, a 31048 CV Barehead trapper, also in yellow handle. The later is a trim little, long and lean sweetheart that rides very well in the back pocket. Currently I'm carrying both, the sodbuster in the front pocket and the slim trapper in the back for a day to day comparison.
To digress from the subject a moment, I'm finding that having both works well as I've found situations where one blade or the other works better for each situation. I know, I could just carry a multi-bladed knife and be done with it. I have one, mentioned later on the way to try out for that role. I just like the carrying and handling qualities of these two single blades.
Getting back on subject, I think the muskrat would carry just as easy, if not easier than a Case YH stockman, either medium or large. The muskrat certainly has a smoother profile with it's rounded bolsters.
With the good stuff out of the way, there are a few less than positive qualities with the Rough Riders. On the muskrat, with its long, equal blades, one backsrpring is nice and strong while the other is soft. When closing the blade one gives a soft schnick while the other goes SNAP! Since both blades are the same, until a means of identifying the weak side on sight is determined, you will have to wait until you start to open the blade to determine which side it is, the soft or the strong. I could see using the softer side for things like letter opening, cutting wrapping string and paper, while reserving the strong side for meatier tasks. On another specimen you might find both springs strong, or both springs weak. That's one of the down sides.
The Barlow's big weakness is that the small spear blade sits just deep enough into the frame that the nail nick sits about 90% or more below the frame. With practice you can shove your thumbnail in and down to engage the nick, but it does take some work and practice. I find the clip profile on the main blade a bit blunt looking. Not a funtional issue to be sure, but it is just a wee bit off putting.
Speaking of blades, both are 440 stainless. I've been told 440A, but can't be sure as the blades just read "440 Razor Sharp Steel." Okay, it isn't carbon steel and it isn't even 440C, but it is certainly a usable steel for a pocket knife and not bad if you are carrying it and using it in a humid, sweaty environment. It just isn't carbon steel or D2. All four blades came usably sharp. However, on the barlow I would probably introduce it to the sharpening stone before really carrying it. On the muskrat one blade was shaving sharp, though not frighteningly so, and the other didn't shave, but was none the less pretty sharp. The old slicing the paper edge routine was easy with either of the muskrat's blades and neither blade encountered any catching along the length of the draw. The sharper of the two, which coincidently was the one with the strog backspring, would cut thin, curling, strips of paper with ease.
For these two samples that is pretty much the best and the worst of it. In any knife over $20 I would be disappointed and feel ripped off, but for half that, or even a few dollars over half that, they are a good value for the dollars spent.
As someone else mentioned, and my apologies for forgetting who it was, when they examined a table of them there was some variance between knives, even of the same pattern. I would say that sums it up. They aren't bad knives at all, just some are better than others. I haven't seen others to compare with, but I am going to speculate the fit and finish when looked over is probably going to be pretty good. I think where the inconsistencies <sp> will be found is in the blade sharpness and the backsprings. If they could get these things worked out to the point of producing all their knives at the level of their best while keeping the prices so low, then these have a good chance of becoming a darned good, inexpensive knife line.
I paid just under $10 each for these including shipping off of ebay. This particular seller won't combine shipping, but did ship quickly. Both knives are lovely to look at. The barlow with its horsehoe logo and the RR inside and the rounded lines reminds me of some of those pics I've seen of the Russels, in that they have that look of an older barlow. It looks like classic American. Both knives look anything but cheap.
I would certainly, and probably will buy more as long as I can get them for under $15 each shipped. I'm thinking that if you could get with an online dealer that would be willing to hand pick them for you, and I'd pay up to a dollar extra for that, with the emphasis on what you are looking for, say best scales, best snap of the blades, or best overall, you could build a lovely, yet inexpensive knife collection with a variety of patterns and stock materials.
Am I going to quit buying or carrying Case, or Boker, or any other quality American or European slipjoint in favor of these? Not at all. Despite their not having any walk and talk, and that they are over polished in a places, I like the two Case yellow handles I'm currenlty carrying a lot. I hope to gradually add more German and better American blades such as Queen to the slowly growing collection.
There is still something intangible in the holding and using of classic knives by classic companies. When you wrap your hand around a Case, a Boker, Kissing Crane, an earlier, genuwyne U.S.of A. Old Timer, or any other classic, you are wrapping your hand around a tradition and a history, and rubbing shoulders with a brotherhood that understood that a solid working knife is a part of their life experience, hence an inseperable part of them. Even if these Rough Riders had all the bugs worked out, no matter how good they look, or how hard they work, they just can't pass on that intangible heritage. In a way it's a shame as they have the potential to be a nice knife, even at comparable prices to the American/Geman knives. But for us dinosaurs, being made in China, being only recently born, they just can't quite touch that spot in our hearts. Thank goodness there are still companies out there that can do that.
Just for perspective, during this ebay cruise out of six knives purchased, two were Case Yellow Handles, two were Rough Riders, and two, yet to be delivered, were stag scaled Bokers, one of which is going to get tested out as a carry knife. Since that one is a multi-blade, a congress, my two current carries might need to worry some. Then again, I have four pockets, why not carry four knives in different patterns.
I would, however, take one of these over a new Schrade even if the Schrade was perfecet in every way. The Rough Riders, and consequently the Steel Warriors and the Boker Magnum Bonsai series are what they are and what they started out as, Chinese made pocket knives made in mostly American traditional patterns. They don't represent the selling out and the trading on the name of an American icon. Schrade quit being Schrade when it closed the doors and sold the name to Talyor who hauled keister to China for production. Remington knives took a dive when they left a long standing relationship with Camillus and started having their knives made in China. Sure, all the knives are made in China, but one set is just up front and honest, not trying to trade on a history and tradition, while the others, well, I don't care much for it. It may be just business, but it isn't clean business. Companies like Boker have always had an operation or two in different countries. They do however, treat them as seperate lines and each is marketed as their own line. So you have Tree Brand, Arbolitos, and Bonsai. I can get behind that. It's honest. Trying to sell on the great historic American traditions of the Uncle Henry while passing me a China made knife with the Uncle Henry name on it isn't.
Sorry, got a little political there. Anyway, bottom line is, they ain't bad knives and the are pretty darn nice to look at and hold and I wouldn't be ashamed to be seen with one in hand. If you were to open the weak side of the muskrat instead of the strong side, that might be a little embarassing, but just looking at laying in my hand, I wouldn't sweat. And if I did, the blades are stainless. If you like exotic stocks, but not the exotice prices as I do, these might provide a way to build a looker collection at a minor price. And, you can even use them if you need or want to, they should work well enough for general cutting, though only time will tell how good they hold up to regular use. I lean more to the collection of lookers on these. I have other knives for carrying.
That's pretty much it. Good thing since this is a little long. I know, I should have put this over in the Reviews forum, but that would be like leaving a bunch of fellow bullshooters on the bench outside the general store munching moon pies while I went off to the new Starbucks in town to tell my tales. I like it better sharing it with you guys.
I have a few of these that have so far held up well and for the money are good knives.
These three I suspect were made by the same company in CHina even though they all have different names.
Camp USA Trapper
Rough Rider Copperhead
And one that I got just recently, an Elk Ridge Stockman, similiar to a Case "18" pattern. This one is VERY well put together.
I'm not a huge fan of 440A steel, but I can't say it has ever not cut what I wanted to cut either.
I own a couple of Rough Riders and they are a good knife for the money. I regret the China thing, but they are at least honestly Chinese like Amos stated. Mine are a white bone Deerslayer and a white bone large Sunfish/rope knife. The Deerslayer is great, strong backspring, nice blade, etc. No other company makes a knife in this style that I have seem except for special model Case Family Brands model in ATS-34. Very nice to be able to get this huge nice knife for under $15. The Sunfish is decent but has a lazy backspring on the main blade. Mine are a few years old and don't have any half stops. I have considered picking up a few more of these to offer myself a greater range of slipjoints for minimal money but I always cringe at the made in China thing and really much prefer carbon steel on slipjoints.
Confederate, nice examples, thanks to posting them. I think you are probably right in that there is probably one factory producing several brands. Kind of a Chinese Callimus if you think about it.
Drifter, do you have a picture of that Deerslayer by chance? It sounds interesting. I've liked the look of the white bone and the mother of pearls I've seen, at least I've seen them on the internet, just not in real time. I may have to check the local gun show sometime to see if there is anyone there selling any RRs or similar. Of course, some of those boys at the gun shows get some silly ideas about pricing.
I will say, that as pleased as I have been with them, I still hesitate to buy them sight unseen. I normally buy them when I can hold them first becuase I have seen times at gun & knife shows that a seller had 15-20 of a particular pattern, but only 4-5 were perfect, the rest being rough enough I wouldn'y buy them.
As our cutlery industry goes down the drain,Schrade,who's next? Who sold out,Case,Queen?? Still made in the USA as far as I know.Enjoy the Chinese knives *barf*
Right on, tombstone, right on.
Quality is the last thing I am thinking of when looking at a Chinee knife. I think loss of manufacturing jobs, end of tradition, things like that. A person that loves collecting knives can fill their shelves, displays and safes (???) with, or carry in their pockets, Rough Riders, US Classics, faux Schrades & Remingtons & Winchesters. Or: that person could find old, American made knives that deserve the 'collectible' tag and show what old time quality was really all about. Some of these are priced as low as one Chinee knife. Other's may cost what two or three or four Chinese made knves do. To me, which is the better value, which has more collectibility, or is more historically important, is obvious. Others may feel differently.
Just an example: Purchased at a flea market for ten dollars: A Camillus 'Silver Sword'- the company's premium brand) in mint condition in the great old original packaging with a sharpening steel. Looking through my old catalogs (part of the pleasure of collecting) I see that it is circa 1978. It has strong backsprings, carbon steel blades, delrin handles (called 'cabone' by Camillus), the fit and finish is excellent. A valuable collectible? No, not really, not to most people. But a solidly made American product that would serve most of us the rest of our lifetimes as a user.
That's okay, I went and bought a Case yellow handle peanut at the local hardware store after being sadly disappointed in one of two recent made Boker's I'd purchased long distance that I really had hope for. More in a separate post.
One nice note. The Case Peanut actually walks and talks. The first one that does so out of five Case CV YHs I've purchased in the last few months.
Based on past experience I really expected more from a Boker, German made, not the Argentine or the Chinese made ones. Backsprings on the Congress are just wimpy. My Boker Barlow from about 6 or 10 years ago walks, talks, and snaps with authority and it's gotten wet and rusted in bad storage experience.
My only concern with old, collectables is I don't have enough knowledge about them to keep from getting taken. I've already got my head crammed with specs and info on a number of other things and a heavy learning cycle is just more than I can squeeze in at this time. Hence, I stay with current/recent production stuff that I can easily research and that doesn't have a high collectable status, hence high price.
Drifter, sorry, the link didn't work for me, but thanks for trying.
Off to do a growl post about the Boker.
Amos, sorry the link did not work. I did notice some Deerslayers over at eknifeworks.com (Smoky Mountain Knife Works) today. One was a buffalo horn scale model, no white bone there at least.
Boker seems like a mixed bag. I bought one congress that had a huge gap between one scale and the bolster one time without looking closely enough, but I got to take that one back and get a blue bone one with a better blade combination. The new one has some blade rub but I am not taking it back. On the plus side, they are reasonably priced and are available with carbon steel.
Drifter, no problem. Thanks for the point to SMKW.
As I mentioned in the Boker thread, I've already gotten a response back. Since this one is an Off The Wall, non catalog item I was told to pick out a comparable one and send this one directly to them. I can't complain about that kind of treatment. I'll just have to try finding any future ones where I can look at and handle it.
That kind of personal customer service is one thing that I don't think will be found with the China mades anytime soon. It is just one more of those intangibles I was talking about earlier.
I like the Camillus,nice catch for ten bucks! I Wish my local flea markets had good stuff like that.
Me too. Usually every place around has been picked clean by folks gathering to sell on ebay. What's left usually isn't worth looking at, but you still have to. Just in case.
Nice knife btw. My experience with the Camillus made Remingtons in the past has been excellent. I wouldn't mind adding a few Camillus to the herd.
I'm not ashamed to say that I've got probably 40 Rough Riders, most all of differing patterns. I don't think that they're a Case, but it was a way for me to get good examples of MANY different patterns in a cost effective way. They're in general, a good little knife for the money. They strop up pretty sharp, too.
I have accumulated at the same time, a nice Schrade Old Timer collection (many are used, but still solid knives), a pretty complete collection of Remington/Camillus green & yellow delrin folders (I always found these knives attractive), a decent little Case XX collection, some older Gerber lockbacks, a couple Boulder Westerns, older Bucks, and numerous other cost effective "name" knives.
I don't exactly "love" Chinese knives, but I have them. I also have several pounds of US knives, too. I always have tended toward American or German knives, but I'm enough of a realist to know that I could never afford to build a collection of Case XX patterns as quickly as I did those RR's.
YMMV, -FNR.
Does anyone know how they test these knives? I've seen that many are marked "tested sharp" on the blade, but don't see anything explaining how this is done. Is the testing occur in China or when they arrive at the importer's? Does the importer have a website or somewhere to go with questions? Who is the importer? Thanks.
I suspect that its just a marketing gimmick, playing off the famous and highly collectible CASE TESTED XX trademark.
The "Steel Warrior" line (which is probably produced in the same plant as Rough Rider) has an actual Rockwell divot on one of the blades, along with a sticker saying that the blade has been tested to 57 or 58 on the Rockwell scale. Like an old Puma. I assume that would be done at the factory.
Thanks, fellas. The Case and Puma knives were (and to the best of my knowledge still are) tested at the factory. Both companies have stressed this with photos in their company literature. I have seen that the "Steel Warrior" and Coast Cutlery knives from the PRC use Rockwell testing divots, but have not seen these on the Rough Rider blades. Even the little sticker gives some idea of having an extra QC step. It sounds just shy of shady if it is the case, as Knifeaholic suspects, that the marking is just there to resemble another maker's mark. It would be nice to have more (some, any) information from the importer.
From my limited experience with the Rough Riders I would have to say it is a marketing thing as the blades on the two I have run from very sharp to kinda sharp. If each blade is tested razor sharp then the person doing the testing needs replaced. Unless the blades are sharpened before assembly and the assembly process dulls some down. Either way, while I think the knives offer a lot for the money, I am not impressed with their idea of tested razor sharp.
LOL, that's a good one, Amos. Sharpening before assembly is, of course, the height of folly. Along the same lines, I notice that they often use an anvil near the "tested sharp" etch. Maybe they whack the edge on the anvil to test it! How much luck did you have sharpening up the "kinda sharp" knife? I would like to see you continue the review of these as users (since like me, that seems to be your primary interest in the knives you get). Your stuff is always fun and open minded. Thanks.
