What is the explanation for some old axes showing a "rounded" hardening line? My thinking is that dipping an axe in the quenching liquid would yield a somewhat straighter line, depending on how they were lowered. I'm thinking this effect you'd get if you were "spinning" axes slowly on a wheel holding several of them at critical temperature and would just lower them to be quenched.
Does it have anything to do with inserted bits, and the higher carbon simply reacting differently to heat treating? If it does, is there any connection usually between the exposed inserted bit's area and the depth at which manufacturers would harden behind the edge? In other words, is there usually a connection between the forge-weld line and the hardened area (extending up to this line)?
Hope this makes sense.
