Hi...I am somewhat of a newbie when it comes to putting on knife scales and then grinding the scales flush to the tang and then making it look like it was made by a professional blade smith. How do i go about making the blade that has been profiled and then with scales epoxied on/ground flush to scales with tang so you don't see the grind lines if i use a vertical belt sander setup? basically with my vertical belt sander you will end up seeing sanding/grind lines that are going up and down to the tang instead of flowing horiztonal with the entire knife. Sorry I am not very good at describing what I mean, but i'm sure someone out there knows what I mean. Any advice would be very appreciated! Thanks!
