- Jan 26, 2002
Thought this might be useful to those still learning to sharpen convex edges or sharpening maniacs who want to try new things.
While somewhat absently mindedly rubbing the side of the blade of a folder on my mousepad while waiting for a site to load, I recalled Cliff Stamp's mention of grinding a convex edge with carborundum paper laid down on styrofoam, and using a stropping stroke. How about the mousepad?? Seems a little firmer, should last longer and not permantly compress. I searched BladeForum to see what other tricks might be found, and dscovered that my "invention" had been invented previously by several other people. (Like most "inventions"!)
Here's a couple of links to other, prior threads:
http://www.bladeforums.com/forums/showthread.php?s=&threadid=176756&perpage=20&highlight=mouse pad convex&pagenumber=2
http://www.bladeforums.com/forums/showthread.php?s=&threadid=182200&highlight=mouse+pad+convex
Anyway, I easily reshaped the edge on a diving knife using the mousepad under 400/600/1500 grit paper progression to get a convex edge. I then did a final honing with the green chromium oxide honing compound that comes as a stick (locally available at a wood-working store) applied to very thick watercolor paper, again with the mousepad underneath. Works great. I then tried it on a karda that still had a couple of dull, thick spots on the edge. Again, worked very well. I was able to work the entire bevel (1/2 blade width) and raise a complete burr using the sandpaper if I pushed a little . Progressively lightening the pressure, and working up to the honing compound provided a polished shaving edge with no dull spots.
Haven't tried this on a khuk blade yet, since that had a fairly reasonable edge upon arrival. Something longer to replace the mousepad and a section of a sanding belt to replace the sheet of sandpaper could work better for larger blades though. The watercolor paper comes in several degrees of roughness: rough (maybe too rough), cold-pressed (which I used), and hot-press. The hot press is probably pretty close to smooth leather. 18x24 sheets of this type of paper are often available singly at good art stores for a couple of bucks and would provide several strips. This is strong, thick paper, about nearly the thickness of a paper tablet back and should last a while. No worries about cutting up a leather strop while learning and one could experiment with lots of different abrasives. Stick to oil-based mediums, the paper will stretch when wet, and buckle as it dries.
Obviously, knowing what you are doing and ordering leather strop materal from HandAmerica is the deluxe way to go on the stropping.
OT note on viruses:
If you think HIKV is bad, the guys with the Syperco Sharpmaker virus are really afflicted. Some people seem immune, or mildly affected, but the severe cases are really bad. They want to use it sharpen EVERYTHING. One of them is probably trying to think of way to use one to sharpen his wits.
OT note on viruses:
