Gary W. Graley
“Imagination is more important than knowledge"
- Mar 2, 1999
After getting the fixed blade from Ruike, I was impressed enough to go and get a folder made by them on my own. I watched several review videos and I liked the blade shape and that the edge was ground down thin, like the fixed blade is, so I gave one a go.
Ruike P135 is an all steel scaled frame lock that comes with a sliding safety lock once opened, for those times you feel you need a little bit more security, but the thick lock seems adequate enough to me.
The knife is hefty, I don't have a scale, keep meaning to buy one of those! but it is weighty due to the steel construction. I checked BladeHQ site and they list the weight at 5.94oz almost 6oz folder...I told ya...Hefty !
The blade is Sandvik 14c28n which I have liked for a long time and their heat treat seems to be pretty good, the blade
Closed length is 4.8"
Blade length is 3.58"
Blade width is 1.28"
Blade thickness at the spine is .134"
Thickness behind the edge is .021"
Handle thickness is .46"
Deep carry pocket clip works well
Untitled by GaryWGraley, on Flickr
you can see the grind lines are neatly done on this, the finish does show fingerprints but they do wipe off easily, not like a mirror polished blade would but there none the less.
Nice knife, even with the smooth handle scales the knife locks pretty secure in hand due to the contours and nice guard area provided.
Last thoughts on this, nice knife, detent seems too light, meaning you really need to do a pushbutton/lightswitch action to get it to flip open every time, a light pull and it will just move out of the frame and not fully open. I thought the detent hole might need drilled out but that seemed fine, so not sure what the cause it, but that is one thing they should work on.
G2
Untitled by GaryWGraley, on Flickryou can see the grind lines are neatly done on this, the finish does show fingerprints but they do wipe off easily, not like a mirror polished blade would but there none the less.
Untitled by GaryWGraley, on FlickrNice knife, even with the smooth handle scales the knife locks pretty secure in hand due to the contours and nice guard area provided.
G2
Untitled
Untitled
