Uh, link didn't work. I do know it is pretty hard to ruin a HT when you have any clue what you are doing, though. You either have to press way too hard, leave it on the grinder too long, or just use a speed entirely too high. There is no excuse for not having just a moment to dip the blade in water between every few passes or seconds on the belt. The extra few minutes added is more than worth the whole "not ruined knife" thing.
Grinding/sharpening after heat treat with and without water quenching has been an industry standard since time immemorial.
Most if not all major manufacturers produce their knives this way and most knifemakers do also.
A majority of the shaping and grinding is done pre-heat treat, then HT and tempering is done, then final refinement and sharpening is done.
In order to ruin a heat treat on most blades it would have to be heated above 350-400 degrees (tempering temperatures), depending on the steel. It also depends on the size of the blade.
Cliff Stamp says a lot of words, most of them meaning nothing.
This thread is nothing more than a poor attempt at trolling BRKT by the OP.
