Cyrano
- Jun 13, 2015
I've found many test results comparing FrogLube to other protectants, where the tests were conducted using carbon steel -- but I've not seen tests using stainless steels. Of course, the need for rust protection is much less for stainless -- but we know that almost any stainless (except H1!) can rust, if adequately mistreated.
As I don't know the chemistry/physics of how FrogLube works on carbon steel, I didn't want to assume FrogLube would work just as well on stainless as on carbon steel -- so I ran a simple experiment, using two copies of an inexpensive Enlan folding knife. The blades were labelled as being made of 8Cr13MoV stainless.
One knife was used as a control. It was cleaned using FrogLube solvent, to remove surface oil/grease. It received no FrogLube CLP treatment.
The other knife was used as the test subject for FrogLube CLP.
Today, I recovered the knives from my garden. I washed them in warm soapy water, to remove surface dirt, then inspected them using my unaided eyes, and using a stereo microscope.
To my surprise, neither knife showed any signs of rust!
The control blade:
The blade treated with FrogLube:
I conclude from this experiment that we're living in a great time, when even inexpensive stainless steel has such good resistance to corrosion.
- It was cleaned using FrogLube solvent, to remove surface oil/grease.
- It was heated on a food-service warming tray until it reached approx. 250 F.
- I applied a liberal coating of FrogLube CLP, and returned the knife to the warming tray for an additional 15 minutes at approx. 250 F.
- The knife was then removed from the heat, and excess FrogLube CLP was wiped off.
The control blade:
