I know there is no hard and fast rules about rust as all steel and conditions are different, but I would like to learn a little more about rust in general.
These questions are mainly sparked by the rust that has appeared on my Mcusta between the start of my shift at work, and getting home (9 hours or so). The thread is here: http://www.bladeforums.com/forums/showthread.php?t=379192
I was surprised that the rust appeared so fast, and on an, as far as I could tell, dry knife. Now I am worried about rust.
1) I try to wipe off my knives with my shirt whenever they are handled, just to get any hand moisture off. I don't have any metal protectant yet, but I plan on getting some. If I use metal protectant on my knives, wipe them off after use, and try to keep an eye on them for rust (so I can remove it before it gets too excessive), will I have a pretty good game plan against it? Should I do more? Am I being excessive? How much should I worry about rust?
2) With stainless steels, is it fairly safe to use the knife in normal conditions (including somewhat sweaty hands) and not worry about wiping it off after use? I know stainless steel can rust, but is it very rare, or should I still wipe down my stainless steel knives after I have handled them?
3) With carbon and stainless steels, how much do you need to worry about rust? Of course they rust easier, but is it so extreme that you must dry the knife immediatly after getting wet? Can I use them without wiping them down? Or is drying them (of normal hand moisture) after each use very important?
4) If a knife gets some rust spots, and the spots are removed with a metal polish or rust remover like MiliTec, are there any long term affects? Or will the knife be as good as new? If someone didn't take care of their knife and had to keep removing the rust over and over, would the knife eventually "die"?
5) How much rust is bad for the knife? Are rust spots mainly cosmetic? At what point does rust become a matter of the knife's health and function and not just looks?
Personal cases:
-My Mcusta has some spots of rust on the scales. Do I need to worry about these right now (i.e. get some Militect tomorrow and remove them ASAP) or can I leave them for now and get some Militec when I get a chance? Will the rust spread? After I remove the rust, will the knife be as good as new?
-I have a Hen and Rooster stilleto that has some rust on the liners. It isn't on the "face" of the liners (where the blade goes when shut), but rather on the sides. So you can only see it when the knife is open and the liner moves into the locked position. Will this rust eventually compromise the liner lock and should be removed ASAP? Or is it mainly cosmetic and not a worry if I don't care about it?
I have a slipjoint that was in the garage for decades and got some rust on the blade and inside the liners. I asked about how to remove the rust and a couple people suggested that if the knife opens and closes fine, then I shouldn't worry about the rust on the inside of the knife.
This got me thinking that surface rust is mainly cosmetic, and that if it doesn't effect the function of the knife (such as by making the action gritty) then it isn't a real concern beyond looks. Is this true? Or will unremoved rust eventually rot out the knife?
Sorry for so many questions. You don't need to answer each one (duh). I am just looking to improve my general understanding of rust, how and when it occurs, how much I should worry about it, how dangerous it is, and what I can do to prevent it without going overkill.
Thanks in advance.
Personal cases:
Thanks in advance.
