Rusted
I have a butifual marble arms knife my grandfather gave me, I decided to carry it as my gutting knife this year. I gutted out a deer last night by the time I got home to wash it off (mabey 2-3 hours) it was pretty gunned up so I let it sit in a bowl of warm water. It is now just horribly rusted, any advice would be much appreciated.
Scrub with steel wool or wet dry sandpaper, lubricated with a lite weight oil, to remove the rust. Wash thoroughly with hot soapy water. Dry thoroughly. Apply a lite coat of lite weight oil to prevent more rust.
O.B.
Deer blood is alkaline. To neutralize it, pour some vinegar on it.
Follow that up with a some baking soda and a water rinse. Spray cooking oil, cooking oil, mineral oil, Vaseline, or softened Bee's wax.
The vinegar will remove the iron oxide. Just don't soak it. Warm the vinegar and rub the blade.
(Coca cola can be used in the place of vinegar. The goal is make the surface of the steel, a neutral 7.0 PH.)
Why does everyone put vinegar on their knife blades? It's insane. Vinegar will discolor carbon steel almost immediately.
Wash the knife with soap and water. Dry thoroughly. Squirt it off with WD 40 to displace any water left.
I tend to believe that 'less is more' in terms of the treatment's aggressiveness, when trying clean up a blade of rust. For blood on a blade, I'd start the same as if it were a kitchen knife used for cutting raw meat: with a dish soap & water wash. Then, for the loosely attached red rust, scrub the blade with some baking soda (my preference - I've liked how that works). Baking soda is just mildly abrasive enough to knock off a lot of the soft red rust, but not hard enough to scratch the steel in doing so. The fine steel wool method would also work. Then WD-40 with perhaps some more scrubbing as desired (w/baking soda or steel wool). Then, when it's clean & dry, oil the blade.
I can understand using vinegar if you actually want a patina on a new & shiny blade - I've done that myself. But just know that while it's in contact, it'll also generate a little more corrosion (rust), in combination with leaving the black oxide on the blade. Own the consequences of that, if you choose the method. A new blade can survive that without much long-term consequence, so long as the blade's thoroughly cleaned up with baking soda to neutralize the vinegar, and lots of rinsing off under running water. For a blade that's already heavily rusted and likely pitted as well, I'd avoid that treatment, as the 'patina' is already there and doesn't need any more help. And it certainly doesn't need any more etching or pitting either. Pitted steel is more difficult to rid of all the accumulated stuff that generates more rust, as the pits provide more places for it to take hold more deeply, and therefore harder to clean up.
