RVW: Ross Aki Straight-Back machete
The review is long, but really worth reading! See pics, words, and get a free beer while you read it (well, two of the three ain't bad).
Link is: http://www.geocities.com/CollegePark/Lab/1298/aki.html
If you like it short and sweet, then go to <a href = "http://www.ilhawaii.net/~knives"> Ross Aki's webpage</a> and buy some of his knives. I give them a 100% endorsement!
My Custom Kydex Sheath pagehttp://www.geocities.com/CollegePark/Lab/1298/knifehome.html
Palmer College of Chiropractic
On Two Wheels
Nice job. Any info how how hard the blade is? Is the temper uniform? How did you find the handle? What about the rust resistance? What kind of grind does it have? It is probably clear in your pictures but I have poor resolution at the moment.
1/16 would sure have excellent penetration, I would not want to be infront of that blade on the downswing.
-Cliff
Cliff- the pictures were really clear on film, but once they are scanned and processed they get a bit fuzzy...as far as blade hardness goes, I do not know. I think you can find that info on Ross' webpage, but I can't be positive it's there. i would have to guess the temper is around 57-60, although I may be completely wrong. The edge is pretty hard, though. As far as having a uniform temper, I found it to be quite well done. Ross uses an actual heat treating oven, so the heating is very consisent.
I probably biased most of my cutting toward the front half of the blade, as this would make sense reach and leverage-wise, but I found no chipping or rolling in any areas. Blade wear, what very little there was, seemed to be uniform as far as I inspected (VERY closely with good lighting and my two eyes).
The handle was very comfy to me. It loosens a bit, but due to the way it is wrapped, it can be tightened or loosened depending on how you like it. The cord was durable and stayed put. It fit my hand really well, and since it is thick cord, it molds to your hand nicely. I was afraid it would be abrasize, but with a little breaking in, the cord softened nicely. This was probably my favorite single feature of the knife next to its ability to perform above expectations.
Rust resistance was good. I did not treat the knife, and I left gunk on it for a couple hours on end with no problems. a little discoloration from the acids in the plant guts, but nothing obvious or unattractive. I rinsed the knife in soap and water and then towel dried it and that's it. No oil or any other product was used to inhibit rust and it is in great shape. The knife is satin finished throughout, and I think a lot of problems with ATS-34 stem from the fact that the blades are usually bead-blasted on "tactical" folders, and I have seen these blades develop rust very quickly.
The grind- the blade is 1/16" throughout, handle and blade, and it is that thick all the way to the edge. The edge bevel is about 3/16" wide, and it is a v-grind right off the 1/16" blade. So, essentially the entire blade is a giant "blade-flat" while the edge is a v-grind with perhaps a little convexity to it, that is 3/16" wide. I don't know if that makes sense, but it's the best I can do. The entire knife is 1/16" thick except for the very edge, which is a v-cut that only takes up a 3/16" border or so along the knife. Maybe that's an even worse description! Somebody help!
On Two Wheels
Chiro :
Excellent, I was wondering about that.
Got it, that is about the bevel length I would have guessed.
-Cliff
[This message has been edited by Cliff Stamp (edited 16 September 1999).]
The pics are good enough to show it doesn't look like an accordian after an hour's use after all, so I'll eat my words.
-Cougar Allen :{)
Well, Cougar, we win some and we lose some, right?
Now I'm sure you could make that knife look pretty screwed up in short order, but within reasonable limits defined quite clearly by the maker, the Straight Back performs better than expectations.
On Two Wheels
