RWL Home Heat Treat.
Is there an easy heat treat setup i can do at home for hardening RWL 34 Stainless? I've heard with some stainless's you can just run a torch up and down the blade until it loses magnetism. Does this work very well and for what kinds of steel?
Same goes for D2 is there an easy way to home HT?
I can send them away for heat treat but It'll be at least a week and a half turn around on the blades and i liek to do things myself if i can.
Thanks in advance.
Tim.
No, you can't get any result just heating it with a torch. You need a temp. controlled kiln not only for D2 or RWL34 but for all air hardening tool steels...
Emre
Tiiiiiim,
You really need to stop and read up on steels and heat treatment.
Here is a recent brief I posted with some basic facts. This does not get into the process of heat treating stainless steels , but will give you some idea of what is going on in the bar of steel.
Tiiiim, and others:
It seems clear that many people don't understand what is happening in the steel when it is hardened and tempered. I will try and give a short ( OK, not so short) explanation, but one of the problems ( like yours) from folks who learn on the internet is that reading three sentences and spending three hours trying to learn a skill is not the same as reading three books and spending three years developing the skill. Even that does not compare to reading twenty books, attending twenty seminars, and spending twenty years practicing the skill. I often get a chuckle from the "experts" who are on their third blade.
OK, enough ranting:
Steel is a combination of iron...usually about 99%, and carbon...usually about .6-1.0%.
To that they add small amounts of alloy ingredients. Some are to make it easier to make the steel, such as silicon,phosphorous, sulfur. Others are there to enhance the properties desired in the steel -Manganese, Chromium, Vanadium, Tungsten,and some others.
The alloy ingredients form various structures that are often in the form of carbides, which can make the steel harder and tougher. This comes at a price, though, over a simple steel alloy (with just iron, carbon, and a tad of manganese). Once you start adding things like chromium and vanadium, you need more heat and longer times for these to go into solution.
When the alloy becomes overstuffed with these ingredients, as in martensitic stainless steels, the iron content is reduced to as low as 70% and things like chromium, vanadium, and tungsten go up to as much as 20%. Carbon often reaches nearly the proportions of cast iron ( 2-3%). The excess carbon is needed because of the amount of carbides formed.
What does all this mean to knife makers??????
We want our blades to have a combination of two things - Hardness and Toughness.
This comes from creating a structure in the steel called Martensite. We can then manipulate the martensite into a desired blend of hardness and toughness.
So lets get out steel hot:
When we heat the steel up to a point where the atoms start to rearrange, the first major change comes around 1350F. That point is the Critical point - Ac1 or As,which means it is the beginning of the point where the steel converts to Austenite. Austenite forms at slightly different points depending on the alloy ingredients.The word "critical" means that there is a change in the physical properties (solid,liquid,gas, structure,etc.) at that point.
Next we reach the Curie point at exactly 1414F for steel. This point is the same for all steels. Its abbreviation is Tc. This is not a physical change, but deals with ferro-magnetics. At this point the steel becomes non-magnetic. Of all the "tricks of the trade" that smiths will tell you, this is the only one that is entirely accurate and repeatable. When the blade stops sticking to a magnet...it is at 1414F.
Then we reach the point where the alloy ingredients are able to go into solution. This is the target point. This point is often called Ac3 or Af. NOTE - Charts with the "s" and "f" used are easier to read, I consider that the letters mean "start' and "finish". For this reason, I will use those terms. The target is the place where all that we want to happen will, and things we don't want won't. Grain growth is the enemy when the steel gets too much above the target point.
Engineers have spent many years doing tests on steel to determine what it does and when it does it. Each steel type has its own set of data. This data is put into charts by engineers, because they do that sort of stuff for fun.
A look at one of these funny charts with funny names like TTT or ITC will show a bunch of curved lines. The curve sort of looks like a nose, and the left-most spot is called "The Nose". That "Nose" is usually about 1000F on the chart. This is the point where if your steel goes any amount right of the nose in its cooling ( takes too long to cool down), it will become partly or all pearlite ( which is not what we want). To determine what you want the chart to tell you, look at the base of the chart and the vertical side of the chart. Along the base you will see the time experssed in seconds, and then in minutes. On the vertical side you see the temperature scale.. Thus teh chart shows how soon things happen at any specific temperature . The X/Y coordinates of any sopt on the curved nose line will tell you how much time you have to get down to that temperature durring quench.
All those funny letters and names assigned to the places along the temperature chart tell you where the steel changes from one structure to another. A= austenite; M= martensite; Ferrite is iron and carbon ( body-centric for those engineer types); Cementite is a hard and brittle structure of iron and carbon; Pearlite is a soft structure made up of layers of ferrite and cementite.
Lower case sub letters, "s and f" mean start and finish. Letters "c and r" mean climbing and returning...or simply heating up and cooling down. Note that things don't always happen at the same point rising and falling.
What we are concerned with is taking a piece of steel that we have shaped into a blade and changing it from one structure to another in a controlled process we call "Heat Treatment".
We do this by first heating the steel up in an environment that won't ruin the blade. This is part the atmosphere of the forge, and part how we protect the blade form elements we don't want to add to our steel....mainly oxygen. That is for another discussion, though, and for this talk we will assume your forge/oven atmosphere is right and you did the proper things to protect the blade form evil oxygen.
Back to the funny chart. The steel starts off a mix of God-knows-what structures after we have been working on it. In the final Heat Treatment we heat it up and as it passes As/Ac1 it starts to change into austenite. Then it passes the Curie point, and our trusty magnet ceases to attract the blade. On we go as we heat up the blade until we reach the Af/Ac1 spot. This is where we want to stop heating the blade and hold it at that point ( as close to evenly as possible) during what is called the "soak". While the blade is "soaking" the alloy ingredients have time to slowly recombine into various structures, go into solution, and the evenly distribute themselves. This takes from 5 to 10 minutes for simple steels, and up to an hour for complex stainless steels. As a general rule of thumb, a 10 minute soak is used for carbon steel alloys, and 30-45 minutes used for stainless steels.
The temperature of this varies depending on the alloy ingredients. Simple carbon alloys are usually about 1400F to 1500F, and stainless steels are around 1850F to 2050F.
Once we have allowed the ingredients to go into their solutions and such, we now need to cool the blade down and make Martensite out of it. This is the "Quench" stage. By rapidly dropping the temperature past the "Pearlite Nose" we can super-cool the austenite and thus not make any pearlite. Notice that once past that nose, the amount of time starts to expand as the blade cools down. This is why we need different quenchants and methods for different steels. All we want to do is get past the nose quickly, after that we want to cool down at a rate that allows the steel to convert to martensite , but does not shock the steel any more than necessary. For some steels, like the simple 10XX series, this is fast,one second to pass the nose, but as we add those alloy ingredients, the amount of time to pass the nose increases. The "O" series steels have about ten seconds, stainless steels give you many minutes to pass the nose. Thus, the proper quenchant for these steels would be -
Water or fast oil for 10XX steels
Slower oil for O series and alloy steels like 5160
Air for D-2 and stainless steels.
Once past the nose, we can slow down the cooling rate. The steel needs time to prepare for the sudden change that will occur at the point where it changes to martensite. At this point we still have austenite ( hopefully) and the steel is rubbery soft and in no danger of cracking or breaking. As we reach the Ms point, around 450-500F, the steel rapidly converts into martensite. This is where the cracks come from. The change in structure can tear the blade in half. Thus we need to cool the blade across this area as slowly and evenly as possible. The choice of quenchant can make or break ( literally) a blade here. At about 200F the austenite has mainly converted to martensite. Any left over austenite is called RA, or "retained austenite". This is a very small amount in simple steels, and is dealt with in the tempering stages. However, with the complex stainless steel alloys, this RA is a big problem unless converted as fully as possible to martensite. The much larger percentage of RA at room temperature is due to the fact that ,while the simple steels finished their conversion to martensite (Mf) at about 200F, the stainless steels need to drop to about minus 200F, yes 200F below zero, to complete the transformation. This is done by adding a step called "cryo". The steel can be very unstable with part of it being very brittle martensite and part very rubbery austenite, so it is wise to give it a short stabilizing step called a "Snap Temper". This is a short temper cycle of about one hour at a low temperature of about 200F. This will stabilize the martensite somewhat and can avoid cracks forming in the cryo stage. After this "snap temper" the blade is cooled to room temperature and them placed in a chamber that will cool it to the sub-zero point where the Mf will finally be reached. This is typically done in liquid nitrogen, which is a bit below -300F, or in a solution of acetone/alcohol/kerosene and dry ice, which will cool the blade to about -100F. This is low enough to get most of the austenite converted, but the LN is certainly better. Economics and frequency of use usually decide which type of cyro one uses.
After the austenite is converted, it is a very strained and brittle structure. This is called Un-tempered martensite. This is corrected by tempering the steel at points between 350F and 1050F. The tempering target point is determined by a tempering chart which those engineers have also made up for you. The chart is much easier to read. It shows the estimated hardness at any given temperatrure on the curve. The first temper cycle ( after the snap temper) is to convert the martensite to tempered martensite, which is tougher, as well as convert any remaining stray bits of austenite into martensite. This newly converted martensite will, however, be un-tempered, so you need to do a second temper after cooling to room temperature. A second cryo treatment between the tempers will accomplish very little, and this is not usually done. To make it clear....cryo is done as a continuation of the cooling process during quench. After that cooling has been stopped and tempered, any cryo will be much less effective.
To state it in a flow chart for stainless steels:
Heat to austenitizatuion > Soak > Quench > Snap temper > Cryo > First temper > Cool to room temp > Second temper
__________________
Ok so I am finishing my first blade and already started on my second/third. (yes I'm an addict)
For my first knife and many more to come I am using 5160 from a leaf spring. I normalized, heated to non magnetic and air cooled, twice. Then cut, ground, sanded, into shape. Heat treated in a kiln to 1550 soaked and quenched in oil. Then I tempered the blade in the oven ~400 for about 2hrs. It turned out pretty good, I think for my first knife and I am working on finishing up the handles and polish/sharpen. (Will post pics soon)
OK well on to the question, haha. I used my friends kiln for this and would like to not have to go to his house and beg the use of his kiln. I do not have the funds for a kiln, and am wondering the best way to tell temp in my small forge. Do I just go off the color charts? I used 5160 because, from what I have read, not 25 books or lectures, it is easy to work with and forgiving. Make it look as close as possible to the right color and call it good? I know practice is best, but advise cant hurt, right. :D
Haha sorry you seemed like you got the answer you were looking for, and I thought it was along the same topic. Pics coming tomorrow, just had a little boy!! I'm a bit distracted.
I'd recommend purchasing a thermocouple and a digital readout from somewhere like Auberins.com. They're not that expensive, and they will get you a real good ballpark of you temp. The trouble with using a TC in a small forge is the false reading that may be given by the TC being in the flame swirl and the hot/cold spots you typically see in such forges. A way around this is to use a baffle in the forge which is just a pipe (not galvanized) large enough to fit your blade in. This will tend to even out the temps, and you can take your temperature reading from inside the baffle.
--Nathan
