?'s about BM 710 handle.
How good is the highly compressed epoxy and woven glass composite handle? How would you compare it as far as durability to the AFCK carbon fiber handle? The 710 has a nice looking blade! I would like to use that as far as utility purposes, is that a good idea or do you rcommend something else?
IMHO, the 710 has one of the best utility blade shapes I've had the pleasure of using. Perfect point, a bit of recurve, and a good amount of belly. The edge is also thick enough not to chip out too easily, but thin enough to cut well.
I wouldn't worry about the G-10. The finish on the 710's G-10 is exactly pretty, but its tough as hell.
Bladeswinger, does "good" = "durability" in your question? In the normal sense of the word (durability), I would take G-10 anyday over carbon fiber. However, the 710 was also offered in a limited edition with aluminum scales and an M2 blade. Some people may be concerned about scatching the black aluminum but I have not had any scratches on mine to date. Imo, for metal handle lovers the aluminum scales offer a different kind of "durability" over G-10. The 710HSAL is no longer in production; however, you might find one in the aftermarket if it is the sort of "durability" you're looking for.
Edit: Oops, my bad. The 710AL comes with a 154CM blade (not M2). My confusion is because I was contemplating the swap of an M2 blade on a pre-pro 710 with the 154CM on the 710AL (I like the aluminum scales). I never went through with the plan but I belive Steve Harvey had made the swap on his knives and liked the results. (I envy him). :D
Thanx Buzzbait, I checked the BM site and was unable to find the 710 G-10, can you help me find a picture? This maybe my next purchase!
G-10 is the standard scale material of the 710. It's available on all of them. BM tends to refer to it as "glass-reinforced resin material" but it's all G=10.
BTW, Buzzbait said it--the 710 is one of BM's best design successes!;)
Just a little info on my meaning of "durablity". Can you use it as a striking weapon, for example, can you hammer fist it into someone's head?
Well... It seems to be a good choice for my next. I like the good reviews you all have to say about it, it helps me easily make up my mind! I guess the Cold Steel Recon 1 folder may have to wait!
AFCK 806D2 comes in G10, I haven't seen a carbon fiber version.
I would tend to think that any kind of non-POS blade can be "hammer-fisted into someone's head" without it falling apart.
As to why you would want to do that when you have a perfectly good pointy end on the knife... :)
I tend to use the blade as a last resort. If I can strike the butt of the knife into an attackers face to slow him down enough to get to a safe area then no need to "slash and thrust" but if the attack continues.... Then, alternative measures will be taken! ;)
There is enough handle at the butt-end of the 710, so that it could be used as an impact device.
BTW, if you order a new one, the latest models are being shipped with bronze bushings. You might want to check that out if you are a "bronze bushing" fan.:cool:
I have dropped my 710 onto the tarmac while riding a bike, the SS liners some dents but the G10 after wiping with oil looks like nothing happened to it!
I have a 705, the 710's baby bro, and it is PLENTY durable, and will withstand plenty of abuse I'm sure :)
Matt
