- Apr 3, 2020
Hello.
I have bought the S1 Pro.
Having Jääkäripuukko 110mm I have gotten used to its superior rubber handle. I just had problems with moisture and occasional blood on the blade rusting it, I usually do not mind the weather I am camping in and sometimes choosing time and place is not optional. I also decided to "upgrade" to a longer blade.
Knowing the limitations of steel I chose to pick the so called tier 1 knife so it should last in use.
And thanks to this forum, I could study ahead about its weaknesses. Handle and sheath.
I have also wielded A1 in a shop and it had quite rough and smallish handle.
Just to admit, I do not NEED this blade. But it should add adaptibility to my use cases, which is mainly firemaking and sometimes cutting fish and such.
I always carry my Leatherman Charge Ti so I can use it for small tasks.
I just like to buy (not collect) functional and beautiful items whenever I decide I get something.
So far I have gathered these options:
Sheath:
-Fix the locking mechanism by bending it inwards after heating the plastic with heat gun or boiling water
-Buy one of the awesome aftermarket sheaths like vegvisir creations
-Make my own by trying to warm some plastic tube??? It will not end well
Handle:
-Use some kind of paracord, I just bought some lovely paracord and I am thinking that I could maybe take just the outer layer and wrap it around if it otherwise makes it too thick.
How does paracord work for your grip?
I can see myself handling wet and then frozen paracord handle, swearing very much. But I can always remove it.
-Ask some knifesmith to make a new handle for it from stabilized wood, like curly birch.
-Attempt to make my own handle with epoxy and jute like that one forum member here.
-Attempt to plasti-dip the handle? I really do not know how well it holds on, apparently it works very well?
Thank you for any input!
Sheath:
Handle:
