I have encountered one concern regarding S30v microchipping when repeatedly cutting comparative soft cardboard or other fibrous material with a blade having a relatively thin edge grind angle. (30 degrees or less) The fibrous structure of the material being cut can grab onto the edge of a micro chip or tiny crack. Absent the full supporting structure of surrounding steel, the localized stress can rip out a small section of the cutting edge. This creates a larger chip which presents a greater opportunity for more fibers to grab the edge resulting in larger chipping. A vicious circle of cause and effect. The solution, I've found, is a careful resharpening below the depth of the chips and a polishing of the edge to prevent cutting material from getting a grip. This has largely eliminated the problem. So far, I have only encountered this with blades made from S30v and D2 steel. Or, I could just be old and senile. OldDude1
