- Feb 16, 2010
Belt finished pre-HT to 220 grit, I belt finished to x30 post-HT and hand sanded to 400 grit. I went through about 10 sheets(1/3 sheet) of 600 grit cut to 1" strips on a titanium square and aside from a few 600 grit marks in the perpendicular direction, I got NOWHERE! I took it to the pad sander and after about 6 sheets(again, 1/3 sheet) it did remove the 400 grit lines, but I really don't like the little 600 grit circles. I went back and hand sanded back to 400 grit and now have a nice, clean 400 grit hand rubbed ricasso to tip finish. It only took a couple strips to get it that way.
Is 400 grit the limit of hand sanding S30V? Do I need to press harder, or is it bad paper?
The 400 grit paper is GatorGrit, the 600 grit is 3M.
