t1mpani said:
I can't figure why they haven't spend more time promoting 3V.
It was promoted strongly initially, very heavily by a few makers, but it was replaced by S30V which was promoted to have extreme levels of toughness, initially put up in the same class as A2.
... the basic shape of a convex edge--where lateral/crushing force applied to it is spread out along a curve rather than a flat plane--slows edge degredation.
It is amusing the things you don't see but which become obvious when someone else mentions them. I did a pile of work a few years back comparing v/hollow/convex grinds on harder work, mainly looking at primary grinds and found the exact same thing, but never thought about the very edge with the same perspective, not significantly anyway.
However I would caution a direct link because the typical edge deformation from cutting (not chopping) is usually really shallow as in about 10-100 microns. Now if you look at the steel on this scale there essentially is no curvature, it is too long since I did pure math, but basically any curve, no matter how funky will essentially be a straight line between two close points.
However there could be issues on a more macroscopic scale due to control in a cut, and similar. I switched from full convex to v-micro bevels years back simply due to sharpening time. I can do a micro bevel on a small blade in 2-3 minutes from extremely dull to push newsprint sharp, it takes about ten times as long if I do a full freehand polish, too long when I am running comparisons on blades.
Not a matter of doubting your results ...
I do all the time. I even have other people do partial cutting for me so I can do trials where I don't know how much material I have cut just to check that I am not unintentionally biasing the results somehow. Most people interested in information don't mind being doubted, I would encourage it if anything. The best thing that can happen is that someone corrects you and now you know more than you did before. The only people that are bothered by people doubting them are those that are selling something.
-Cliff
