S30V Native - lock problem? No. 2
Hi Sal,
since my S30V Native probably has a weaker spring tension than 'normal', closes softly and, since there are difficulties in sending it back to you (your suggestion), I am considering a possibility to leave it as it is - provided a weaker spring tension does not influence a lock strength.
So, my question is:
Does a weaker spring tension produces a weaker lock strength/reliability?
It seems to me that, once the blade is locked, it does not matter if the spring tension is stronger or weaker.
Of course, if it makes a lock weaker, then I have either to send it back to you or buy an another one.
Thanks,
Franco
If you do worry about the spring, I would suggest you send it back.
It does not affect the lock.Most of the FRN Natives do have a weeker than normal spring.I would perfer a slightly stonger spring but not as strong as the Native 3.I have really had no problen with the weeker spring and it does make them very easy to open fast.
Hi Franco. If the lock is engineered and built properly, the spring tension does not add to lock strength. Spring tension does affect self closing.
sal
