- Jan 6, 2008
Hello again!
I'm searching for the perfect steel or to be exact, steel combinations for a future utility/hunting knife model. I've read all that I can find on the net but now I just get more and more cunfused.
The blade will be about 90mm long and will be both sold as finished knives and as a blade only so makers can make their own handles.
The blade will have a tickness of about 0.156 and will probably be scandi ground to zero, so it will have a rather thin edge. What do you think of this grind?
Now back to the steels. I will atleast use two different steels and one will be 01 so I'm looking for a more corrosion resistance quality steel as a complement. I've heard a lot of good things about cpm3v but is it enough resistant against corrosion to be a good complement to 01? The blades will probably be blasted (not the 01) so this will effect the corrosion resistance as well.
Wich of the following stainless steels would you suggest for me, s30v s90v or 154 cm? If I go for three different steels I will go for 01, 3v and one of the above.
The blanks will be watercut and should be relativly easy to grind and heat treat, I'm familiar to ht rwl-34 so compare to it.
I've heard that s90v is hard to grind how hard is it compared to rwl-34 and 01? Is it hard grinding it when anneald as well as heat treated?
These blades will be made in batches of about 100 blades so grindability is a thing I have to consider and so are the heat treating.
All toughts and comments are much appreciated!
Regards Jakob
Regards Jakob
