Both of my blems have almost the same '"waver" in the grind on the clip side, curious as to why that would happen? I assume that if you aggressively re-profiled or sent it to T. Krein that it would go away. Am I correct? Thanks, Russ
With the waver in the same place on both, apparently one of the mechanized as opposed to manual steps of the grind process is where the problem occured, probably an incorrect setting...
I would think reprofiling (or most definitely TK) would take care of it...
