SAK Blade Wobble
Razor
I have a hunter model that I have used several years hunting, and it has got some side to side blade wobble. I really like this knife, and was wondering if I can do anything about it, or would I have to send it in to the factory?
Yep its very easy to tighten. To remove the scales without damage soak the SAK in hot tap water for a few minutes, then they will pry off without damage. It usually only takes a couple of hits with the ball of a ball peen hammer to tighten the pivot. Tap gently and check frequently as its very easy to over tighten.
Cheers
It is the hunter. Thanks everyone for the advice. I will try the hammer on it.
