J. Doyle
- Feb 17, 2008
I think I'm going to dive in and mod a SAK to meet my wishes.
The victorinox Huntsman already has everything I need but it's too thick for my tastes and I don't think I need the can/bottle opener layer.
Tools needed: Blade(s), saw, scissors, tweezers.
Tools preferred: Corkscrew, awl.
Questions:
1. It appears I may have to sacrifice the awl for the parcel hook as the hook appears to be always paired with the scissors. Does anyone know if the tang of the awl can be modified to work with the scissors and spring?
2. I plan on reassembling with the original brass pins/bushings. How much pin stock do I leave sticking up above the bushing/cup to peen over?
3. Is some sort of shim stick needed during peening to get correct tension on the blades/Tools? I'm assuming if you went nuts you could lock the blades up. Or not enough and you could have blade play.
Perhaps I can document the build in thus thread.
Questions:
