I would suggest a 40degree angle on your sharpmaker because the steel is pretty soft.
I convex sharpen my SAKs using the mousepad / wet&dry paper method. Its very easy to do and gets the blade extremely sharp. If you try this method, just remember to hold the blade nearly flat to the paper, you only need to lift the spine slightly.
Chris "Anagarika";6087766 said:Once you got it sharpened, regular stropping brings back the edge easily, unless you use it on cables / wires ..![]()
