Can-Opener
I had always thought that the different sized SAKs (84mm thru 111mm) all used the same basic tools.
That is until I recently got the 84mm Victorinox (Economy) Sportsman II - see this linked thread if you have access to SOSAK.
Looking at this 84mm model more closely I realized that not only was it (obviously) shorter than the standard 91mm models - but it was narrower as well - one can just discern it in this photo:
Anyone with both 84mm and 91mm models can simply put one on top of the other to see the difference.
Glancing at the Sportsman II can-opener I thought that it was just perceptibly smaller - so I dug out a representative example of each size (84mm, 91mm, 94mm and 111mm and even the SwissTool) and compared them.
One can (pun intended
) just about make out the 84mm Sportsman II can-opener is just perceptibly smaller/narrower - perhaps hard to see for some......
However surprisingly the can-opener of of the biggest SAK the 111mm WorkChamp seemed smaller too......
Close up of 84mm and 111mm compared to standard 91mm
Hopefully one can see that the 111mm is not smaller - because it simply sits further in the handle making it look smaller - look more carefully at its width. Notice how the 84mm Sportsman II can-opener is smaller - both shorter and narrower.
I've seen some other people say that the can-opener of the Soldier is bigger/heavier duty.
This is NOT so, at least on my one sample of the 02 Soldier bought recently - it seems the same size
Close-up compared to the standard 91mm, and 111mm SAKs as well as the smaller 84mm -
Vincent
http://UnknownVincent.cjb.net/
http://UnknownVT.cjb.net/
Vincent
