Messin around and speculating on adding some holes to the Endura blade. A row of diminishing diameter holes so it would make a sort of "blade grip" for closer work. Also lighten it a bit although that isn't very important.
But, putting the tip of your middle finger in the main hole makes it choke up just about right for small stuff. The handle sits in the middle of the heel of the hand. Not for steady use but good for when needed and all you have is the large Endura with you.
I think I'd try a larger hole than the rest as the last hole towards the tip.
