- Jul 7, 2000
Sal,
I was planning on sending in my SPOT ASAP because the sheath has proven to be insecure. This is what I wrote in another thread:
But now I see in another thread that you say that the sheath is being reworked. Do you have any idea of how long this change will take?
The reason that I ask is because I would like to get a new sheath: I don't want to send this in to just get it replaced with the same kind of sheath.
Please advise me on the best plan of action.
Should I send it in now with a letter asking for a new sheath?
Should I wait until the changes are implemented before sending it in?
What do you think?
The sheath was loose when it first arrived but now it's even worse. Yesterday I was able to get it to pop out of its sheath from bouncing up and down in its chain. Not just once mind you, these results are repeatable.
I see a design flaw in the sheath:
If the knife is pulled straight down, there is an ok level of retention. If there is any lateral pressure towards the edge, however, it takes almost no force to unsheath the knife. The way the sheath is molded, this allows the blade to simply leverage itself out and fall.
It's so bad that you can hold the sheath in your hand and flick your wrist slightly and the knife goes flying out. I've never had a kydex sheath do this before, especially not on a neck knife.
A graphic explanation: http://cpm440v.tripod.com/spot/spotdrop.htm
What do you think?
