Samurai Ninja ?
HI All, Not sure what I got, And I hope you all can help me Identify It. There are no Marking's at all on the Blade or the Sheath, The Sword weigh's 3 LB.'s with the Sheath 3 1/2 LB's,The Blade Is 29 3/8 and Very Sharp I mean like a Razor, Total length Is 45 3/4", I took a lot of picture's any Info. would be Greatly Appreciated, Take Care !
There Is a Blood Grove on the whole length of the Blade,
You can see the two shade's of Steel the Blade across the Bottom as a Grey wavy type steel across the whole length of the Blade
Here's the end cap of the sword,
There are like Gold figure's under the leather on both side's of the Handle,
I'm no expert but the leather ito (cord wrap) makes it look like a modern day production sword. Markings are never on the blade, they are usually on the tang under the tsuka (handle).
looks like a Paul Chen/Hanwei Musashi. The Musashi is a pretty good sword for a production peice. The two tone effect on the blade is due to the differential hardening of the blade (hard edge, soft spine).
I'd guess it's either a Hanwei piece or Last Legend. The Musashi's I've seen didn't have bo-hi. Perhaps a custom configuration from one of them? I recall Last Legend could put together different blade styles, guards, whatever you wanted to order at one point. Definatly looks like a modern piece though.
Thank's for all the reply's & Info, It seem In like New and Excellent condition, But It also seem's of High Quality,I know one thing I love the Blade & how Sharp It Is, Wooo-Weee ! I got some more Sword's I'll show later Today they seem Antique and one Im sure Is a Wall Hanger,Here's another picture of the Grip, The Edge on the Sword Is Unreal, I wish I new What Company Made this Sword Well maybe someone will know "I'm New To The World Of Sword's But I know The Samurai & Ninja Sword's are a Battle Weapon that In Close Range Combat are Second To None ! ! I'm gonna do some research today and try to find It ! Thank's again & Take Care !
I looked through lot's of Sword's and the one I posted above In the link Is the only match for It I found In all Spec.'s lengh and weight and appearance, I wish these Maker's would ID there Sword's ! I'd sure like to know what I got, Thank for all the help everyone, Take Care !
That's the hamon (temper line). Its actually a common feature on katana swords
Technically, it's common on any differentially hardened (using clay, etc) blade where the difference in hardness marks the transition from different crystalline steel structures.
Oh, and typically, as here, it is acid-etched to show it off more.
I also believe it's a Hanwei Musashi - whether it's an older or newer version of that model, or if it is at all - couldn't tell unless I could see it in person.
However, that "double cucumber" guard (tsuba, handguard, hilt, etc) isn't necessarily attributed to Musashi, and is used on a wide variety of Chinese-made Japanese-styled swords :D.
Yep I agree with everything you've said :) Most hand forged katana swords are differentially hardened anyway (unless we are talking about "wall-hangers") so its a pretty common feature. Some like you mentioned are acid-etched to bring it out. Some cheaper swords have cosmetic hamons that are wire-brushed or acid-etched.
If I'm not mistaken, the double ring tsuba was modeled after Musashi's own sword (more info on him below). A lot of production companies have a "musashi" model that use the same tsuba. Musashi (the company) has the double ring tsuba as their logo.
http://en.wikipedia.org/wiki/Miyamoto_Musashi
The Groove on the back of the blade is not a "Blood" groove.
In western blades it's refered to as a Fuller in Japanese blades it's refered to as "Hi" or "Kesso". The main purpose is to lighten the blade without effecting the strength.
