... the Laredo also has an extra inch of blade length which adds to its usefulness in fighting.
Whew...don't know what I'd do without that extra inch of blade length during my monthly duels. ;')
Snicker as much as you want, but I know many, many people who will carry these for self defense and have no desire or intent on dueling. They conceal much easier than most people believe.
Here is the link to discussion on Cold Steel's forum:
Specifically, check out message number 21 on 3/20/2009 by CS Super Moderator. http://coldsteelforums.com/tm.aspx?m=224&high=san+mai+laredo+tang
He said "The SK-5 Laredo bowie is made using cable full tang, but as for the San Mai III Laredo bowie, it follows the same construction, but instead of cable a solid rod is used."
Thank you for your inquiry.
The Laredo Bowie and the Natchez Bowie feature a cable tang San Mai III and High Carbon Steel models. A heavy-duty cable is attached to the tang, which goes ½ way through the handle, and the cable is then attached to the pommel by a screw/nut assembly.
This is done intentionally, as the cable tang is very good at distributing shock and impact to the pommel rather than through the entire handle. This helps prevent vibration that will wear out the hand quicker, and extends the life of the handle as well.
We have been using the cable tangs for these models since their inception with tremendous success.
