:thumbup:Work it open and closed under warm running water. Use an old toothbrush to clean the joints.
:thumbup:
Yep. You just had the order wrong. First you rinse and flush with hot soapy water. I usually submerge the knife, blue painters tape around the blade, and work it back and forth and swish it around. Then rinse under flowing water. THEN comes the compressed air, then WD40. Never done it for sand but works a trick with blades that are gritty from the factory.
