When the knife is ready to be taken to the grinder for the bevels do you for example,
1. Use a 60 grit belt to grind the bevels and then hand sand the rest of the knife including bevels with 60 grit sandpaper....then move on to the next grit of belt like 120 and then hand sanding with 120 on the rest of the knife ...and so on?
or
2. Use a 60 grit belt, then 120 belt, then 240 belt, and so on grinding the bevels in and then when done with the bevels go back and start hand sanding the entire knife from scratch including the bevels with 60 grit, 120, 220, all handsanding? Wouldn't handsanding the bevels ruin the grinders work and take off steel you don't want gone? So my guess is the latter, grinding WITH the grits? (option number 1)
Because the bevels will be whatever grit the belt is when ground but the rest of the knife won't - curious as to how it should be done?
or
