Heck man, I'd say save for another month or so and get this nice Jet.
http://www.amazon.com/J-41002-2-Inc...047&sr=8-1&keywords=jet+2x42+belt+disc+sander The Jet 2"x42" with an 8" disc sander looks and sounds like its a really solid machine, and with a few adjustments could be all you need for a longto to make great knives with! And the 8" disc size is almost perfect, most high dollar disc grinders knifemakers use are 9". With this 8" disc, you can use some good quality Rhynowet sandepaper in 9x11" sheets to make your own discs using any grit you want (from 80-2000 grit) using 3M fethering adhesive. Also, by using that adhesive, it allows you to take off each grit and put on a different one easily, and you can stilll re-use the first one you had on, therefore it saves time and money changing grits.
(See video below for info on what I'm talking about) Not to mention you get free shipping... And I like how it comes with nice
SOLID work rests for both the belt
and the disc, that both tilt, making things like swedges easy to grind etc. This is what I would get If I was looking for a belt/ disc combo when first starting out, that's If I had to do it all over again. Also, it seems a lot of knifemakers use this machine, some even say so in the comment section.. Anyway, that's one idea, take it for what it's worth
Here's the vid I mentioned above:
[video=youtube;PgZogasa13Q]https://www.youtube.com/watch?v=PgZogasa13Q&list=UU6QePp55DOZJ4Vhuu7L84Vw[/video]
-Paul
My Channel
Lsubslimed
