I know I need much more experience sharpening this way but I thought I'd share the results of my first attempt at sandpaper sharpening.
Just to get the hang of things I bought 800, 1500, and 2000 grit wet/dry automotive 3M sandpaper from Wally world. I used the blade on an old leatherman Pulse multi-tool as the test subject. My flat surface consisted of a 1-ft square marble tile I got for free. I used a little dish soap mixed in with the water and clamped the sandpaper to the tile.
I marked the edge with sharpie and seemed to match the existing bevel pretty good when sanding. I only made 20 edge-leading passes on each side of the blade with each grit of paper. No stropping took place.
The blade seemed to get sharper, but only slightly. I guess I was expecting more.
Any advice? Should I use more grits of sandpaper? Should I make more passes?
