I use emory paper, not sand paper. I tape my paper to a wood pallet, like a paint stirrer to keep it and therefore the bevel flat. I use 400, 600, 1200 and the strop on leather. Can shave with any knife I sharpen like that. Also, clamp the wood stirrer to a bench to prevent it from sliding around (C-clamps or spring clamps work nicely). Only time I use a coarse stone is if the blade has been damaged, nicked, etc (mostly on old pieces I pick up and recondition). Keeping a blade sharp is a lot easier than sharpening a dull one.
Rich S
Sandpaper is made with ground sand (silicon dioxide); emory paper is made with corundum (aluminum oxide); it works much better on metal. Sandpaper for wood, plastic, etc - emory for metals.
ALWAYS sharpen moving AWAY from the edge, otherwise you'll cut the paper and anything it's laying on, if not yourself. Also I wouldn't use a mousepad unless you want a convex edge. For a flat bevel, you need a hard, flat surface.
Rich S
Most any hardware store or Wally world (Walmart, etc) carries emory paper; look for the black paper near where the sandpaper is in the store. I usually buy a variety pack that has grits from 320 to 1200 in one package. Ask in the paint department for a couple wooden paint stirrers. Most places will give them to you free.
Rich S
