Can anyone tell me the blade thickness and the approximate weight of the Sarsquatch? Looks like the blade length is around 6.5", is that right? And overall length would be...?
Thanks in advance,
Will
i prefer a speedo over a thong myself but that's just me, a thong might fit you younger hogs better.a thong would be a good idea for serious work.
i'll measure mine for you right now will, brb...
7 and 3/16th blade 12 and 3 quarts oal. :thumbup:
Thank you Heavy and JWBirch--much appreciated.
Interesting that there is a discrepency between measurements on the blade length-- 7 1/8" to 7 1/2". I was interested in blade length from the front of the handle slab to the point--should have specified more clearly.
Can I assume that the front of the handle to the point is 7 1/2" and maybe the 7 1/8" measurement is from the plunge grind to the point?
Thanks again, gentlemen--
Will
ps--appreciate the wardrobe advice, skunk man. You wear your maturity well.
I measured from tip to micarta slab.![]()
i've heard stories of jerry falling against a grinder and coming up with a 2.75" battle mistress, there will be slight variations.
