- Apr 18, 2005
Hey everyone, just wanted to share these since anyone can do it if you have the time & patience. I got the idea to 'satin-ize' my blade from NorCalMtn2, who's done this to a couple of his ZTs. I used 1000 grit wet dry to knock down some of the stonewash texturing (which is basically impossible since the nicks go so deep), followed it up with 1500, then finished with 2000. Surprisingly, the laser etching survived all the sanding almost completely unaffected. Pocket clip was finished with 2000 grit as well. I got my sandpaper at a local auto body supply shop. Still need to do more detailing to smooth out some scratches from the lower grits. Kept the knife assembled the whole time, set it on top of 2 mouse pads to have a soft surface to work on. Gonna send it to Richard J to get the poorly done factory edge evened-out & wicked (out of the box, grinds were uneven on both sides from base to tip, one side had a wider grind than the other, unlike my 0200KW which is 100% perfect). Here are the before-afters, thanks to everyone on this forum for the great ideas & tips I've received.
