satin finish Question
is the satin finish something that is applied, or is it just raw INFI that has been buffed out more? the reason I ask is, I recently bought a FSH at blade west and stripped it. the naked blade is perfect with no dimples at all. it looks like a duller satin finish. I was wondering if I worked on her a bit if I might be able to attain a satin finish looking blade?
Thanks,
CHarles
It's not a coating if that's what you mean. You can achieve it by buffing/sanding.
Sounds like you got lucky under that coating! :thumbup:
Thanks,
CHarles
Raw INFI, nothing applied to it. :thumbup:
Here's a Ruck that Ban stripped, satinized & convexed. You're looking at nekkid INFI... And it looks good, don't it? :D
looks great Jaxx!! thanks for the Knowledge.
looks like I'll be putting some elbow grease into it
Thanks,
CHarles
You should be able to. I just stripped a ratmandu for the first time, and had the same results. The blade was near smooth with few dimples. I started sanding with a 60 grit spongy block last night and it already looks satiny. 120grit, 220 and 400 should be awesome.
edit - you can see the strip results in the Rat forum. No polish pics yet though.
Stripped INFI is the best.
Before
After
Before
After
Before
After
and this one started of Black with Black and Blue G-10
