My personal preference is to satin blades because I don't really see the point of coating a stainless blade, I don't like coatings, it seems to affect the HT, and they make the blade stick and bind in some cutting. YMMV
I also hear that the coated blades are of lower hardness. Thus leading to lower edge holding capabilities. I believe I heard that from Ankerson.
Eh, is this true?
I just really wanna know if the coating messes with the temper. I never thought about it but now that I read it i do feel like blades with black coatings dull quicker in the same steel same mfg. Though it's probably just in my head.
If thats the case then I wouldn't get the black blade. If its not, black blades on spyderco's are nice. The coating is slick and doesnt add much if any resistance to cutting. BM's is rough and makes it harder to cut and ZT is between them IMO.
Just throwing a WAG here, but perhaps the feeling you get on the stones that leads you to this conclusion could have something to do with the coating being harder than the steel? Perhaps you start out grinding a new bevel and address the coating as well as the steel and this feels hard, then as you polish the bevel you are no longer removing stock and grinding a new bevel...so in essence you are just honing steel (which feels softer than when you grind the coating and steel)...so the steel feels soft?
I could be out of my mind?
It just seems beyond plausible that the DLC would lower the hardness of the steel. There certainly could be a coincidental explanation though...some blades are going to test slightly harder than others due to variance in the production...perhaps you have a DLC blade that by sheer chance was hardened to a point lower than your satin blade? Again, I am grasping and guessing here...
The only way to settle this conclusively is to test a couple blades...I forget which member does this sort of testing, but I am fairly confident that Sal would know if there is any merit to the concept that DLC has an affect on hardness of the underlying steel.
