hehehhe close...
Actually it is a small BBQ bought at Wally mart. A professional knifemaker will wince at this though (and perhaps rightly so
Stack up your coals into a little mountain and light them , let them get to red ash state and then carefully insert your piece so that it is covered by the red hot coals , make sure your vents are open and prop up the lid with the bail so that the open space is smaller , your wanting to create a vortex of wind , next I use my little house fan on high and put it right up close , you will see the difference once your air pattern settles in. Keep a good metal magnet nearby and a thick glass/jar(something heavy duty) of ( used motor oil , olive oil - etc).
If you have done it correctly your piece should be red hot in about 20-30 minutes (depending on thickness etc) , this is best done at night so you can see it glowing , use a long set of pliers or heavey tongs and carefull remove your piece and then check it with your metal magnet , it needs to be heated to the point of non-magnetic, if it so then slowly dip your piece into your oil pan/can/jar whatever and let it slowly cool , it is even better if you pre-heat your oil some , the main point is so that it cools slower.
Now I do not fully understand all the finer points of why and how but that
will work , mind you it is quite primitive but not too far from how our forefathers did it.
When your piece is cool , clean it off with de-greaser , polish it up some , you will have a bunch of scale on it most likely.
Then you want to do some 'baking'
Three cycles of 2 hours each at 450 degrees in your oven should do it , after that you are ready to clean her up and do your finishing work.
Now if I am off on any of this someone feel free to chime in please.
Also if you choose to try this , PLEASE be careful !! Do not burn yourself or your house , use common sense.
Good luck and you MUST post pics of your finished piece
:thumbup:
