I use Loctite 324 and 325 to adhere my stone, bone and ivory scales. This stuff cures aerobically, so the stuff on the outside won't be dried up... just wipe off excess and clean with "Goof Off". This stuff is awesome. Its expensive, but considering the fact that the can of activator is enough to last for at least 100 knives and you dont' waste any epoxy mix in and measuring. You tend to use a lot less. The stuff pays for itself all the way.
Speedbonder 324
High impact applications
Amber Color
Gap fill to 0.040
Viscosity 17,000 (higher is thicker)
Shear 3,000
Temp range -65f to 300f
Cure speed fixture 5 min
Full 24 hours
Activator 7075
Comments: good gap fill and temp range. Has a higher sheer rate than 325 but lower flexibility for thermal cycling. If you arent running your knife through constant temperature changes, this is the better choice over 325.
Speedbonder 325
Severe environment
Transparent dark brown color
Gap fill 0.040
Viscosity 20,000 (higher is thicker)
Shear 2,200
Cure Speed fixture 5 min
Full 24 hours
Activator 7075
Comments: This is used to bond metals that move slightly due to temperature changes. It takes thermal cycles very well since it is slightly flexible. It is slightly thicker than 324 so it is easier to apply. The color of epoxy seems to bother people. If you have a large glue seam you can see, you should work on closer tolerances more and worry about adhesive color less.
Speedbonder 326
Fast fixturing
Gap fill 0.020
Viscosity 18,000 (higher is thicker)
Shear 3,500
Temp range -65f to 250f
Cure Speed fixture 1 min
Full 24 hours
Activator 7075
Comments: Great shear strength. This stuff is for speed. It sets in under a minute. If you are into fast production times, this is the one for you. It is used in the jewelry trade to hold expensive stones so its great adhesive. You just have to move fast.
Depend 330
Rough or porous surface general purpose
Gap fill 0.030
Viscosity 67,000 (higher is thicker)
Shear 3,300
Full 24 hours
Activator 7387 or 7380
Comments: This glue is made for all around use. It will stick to (slightly) dirty surfaces and porous surfaces.
All of these adhesives are Acrylic 2 step, no mix structural adhesives. They require a tight space and activator to kick off. They are anaerobic meaning they do not cure in the presence of oxygen. These are fantastic adhesives but no adhesive will over come poor surface preparation. Many cleaners leave a residue that causes exceptionally high failure rates in adhesives. I use pure alcohol that I buy from Home Depot for cleaning. I use a #0 file to roughen the liners where they meet the bolsters and a 36 grit dremel "drum" wheel for the rest of the liner surface. I prep the metal surface just before gluing the scales and wear nytril gloves to do all of the handling after cleaning.
