- Oct 15, 2014
This is my first time working with micarta & I didn't properly chuck my bit on one of my counterbores & it wallowed out the hole slightly (see the photo below, the middle hole is too large while the others offer an interference fit). I'm wondering if I can fill the gap with epoxy that has the sanding dust mixed in with it? Anyone ever try this & get good results?
Also, I'm wondering how you do your counterbores if you use corby, Loveless, or similar fasteners. The process I recently used for this one:
It is a LOT of chucking & unchucking, doing it this way which is a process I would love to optimize.
I see that one of the knifemaker suppliers has a stepped bit that does both holes at the same time, but they are quite pricey at $70 per bit which I feel is VERY expensive for a consumable item like a drill bit. I would love a more efficient, but price friendly method if possible. I'm wondering if I can just grind down a regular bit while it spins in my drill press with an old wetrock to make my own stepped bit? Any insight would be greatly appreciated.
https://flic.kr/p/rrpMbU
- I temporarily glued up my blade to a scale, drill the thru holes
- then knocked the scale off the blade & glued the other scale to it
- drilled the other thru holes thru 2nd scale
- I then used the thru hole drill bit to clamp down the scales so it passes thru the holes when clamped so the counterbore will be concentric.
- I then chuck up the larger bit for the cbore & drill to my desired depth repeating this 5 more times
