I like my Kershaw Scallion a lot, but do not like the stock clip. Too big, too bright, and too hard to use since the tip of the clip rises very little off the handle of the knife and therefore is hard to get started onto your pocket.
I looked over my other knives for a clip swap, and I found that the Kershaw Ember clip, which is a black painted, shorter, deep pocket carry clip with a much larger 'opening,' fits perfectly on the Scallion. The Thistle uses the same clip as the Ember, so if you have one of those already and are not interested in using the clip on one, then five minutes with the proper torx driver will give you a more discreet and easier to use Scallion pocket clip.
If you don't have a Thistle or Ember, they are $18 and $20 on Amazon, so they are cheap donors and will leave you with a usable knife when you are done with them. The Thistle should even be able to use the long curved Scallion clip since it is drilled both sides.
I find my Scallion much easier to use now with its 'new' clip.
First post, first thread!
