Scandi Arete Pass Around Report #2
Comprehensivist
Platinum Member
This is a report on my experience using Nathan’s (“thurin”) scandi Arete pass around knife. This is “Report #2” because, as far as I know, I am the second recipient in the pass around to post a review. If you have not read Michael’s (“RRaconteur”) excellent Report #1, I strongly encourage you to do so. He made many excellent observations and set the bar very high for us who followed him. Here is the link to his review:
http://www.bladeforums.com/forums/s...e-Pass-Around-Report-1?highlight=Scandi+Arete
Before I delve into my report, I need to offer an apology. I received this knife in mid-December at a very busy time in my life a week prior to having ACL reconstruction surgery. The recovery after the surgery left me with limited ability and desire to get outside to do any knife and wood related activity. Nathan is a good friend and he cut me some slack with having the knife longer than agreed. Even so, I should have forwarded the knife on to the next person and caught up at the end of the list to be fair to all involved. I am sorry for the delay I caused in the continuity of the pass around process.
Getting back to the subject at hand, I signed up for this pass around because I own a bunch of convex grind Fiddlebacks, but none with a scandi grind. The premise of this pass around is to try using a scandi grind to see if it changes my perception or not. Nathan’s Arete is an older vintage full tang 1/8” O-1 with OD green micarta over natural with a white pinstripe. The handle is wider and more hand-filling than most current production knives in this model (more on this later.) Since I own an Arete with a convex grind, I thought this would be a good opportunity to compare them side by side doing the same tasks to evaluate performance differences. My Arete is a tapered tang 1/8” O-1 with Oreo burlap and black bolster & liner.
Here are the two knives together.
Those of you that have read my other posts on this forum know that I usually take all kind of measurements to analyze and compare knives. That level of detail is not really relevant to the intent of this report beyond a couple of notable differences that I would like to point out. First the weight difference is 6.0 ounces for the full tang scandi versus 4.5 ounces for the tapered convex. The handle width at the front, middle, and pommel end of the scandi is noticeably wider than the tapered convex. Taken together, these differences mean that the scandi is slightly more weight to carry, but it provides more comfort, leverage, and mass for better control while actually working with it on wood.
Here are a couple of views of the handles side by side.
I do not “tip baton” my knives, but if I did, I would feel much more comfortable doing it with the stronger wedge shaped tip of the scandi versus the fine distal tapered tip on the convex.
I gathered together some Silver Maple branches to use for my comparison testing.
I started with some basic bark peeling cuts. I found it easier to make long even peeling cuts with the scandi grind. I attribute this to the bottom edge of the scandi grind essentially forming a solid guide against the wood versus relying on a steady wrist angle with the convex grind. The scandi was overall more consistent cut to cut in this task.
Next up was some basic notching and angle cuts on the ends. Both knives handled the task just fine. Again, I found it easier to make thinner and more precise cuts with the scandi. The scandi seems to more naturally follow its initial bite into the wood.
The convex grind on my knife made precise cuts too, but my perception was that it took me a few more strokes to get the same results versus the scandi.
After the basic notching, I decided to move on to doing a mini try stick project with a diameter reduction spindle, a square sided saddle notch, and a double saddle with a rectangular keyhole slot. I did the same exercise with each knife.
(Note the Nathan-esque sky & cloud reflection on the blade in this photo.)
My conclusion after doing this exercise was a split decision. I liked the scandi slightly better for the spindle and square sided saddle sections. I preferred the convex for the double saddle & keyhole slot section. The distinction I made here is that I like the scandi for straight and/or perpendicular cuts and I like the convex for curving cuts. The narrower tip on the convex knife was also easier to maneuver in the keyhole cut.
Just for fun, I did a little feather stick section on a branch with the scandi before moving on to the next comparison test. This is definitely one of the strong suits of the scandi. It just glides through thin strips of wood and the curls naturally roll away from the blade.
Scandi Arete Pass Around Report #2 (continued)
My last comparison test was splitting branches for kindling. I tried to use identical length and diameter branch pieces to see if one grind was superior to the other, meaning which one would split the wood quicker or with less force required.
In this limited test, the results were pretty close. The scandi accomplished the final split of the wood just slightly quicker due the wider wedge effect of that grind. Silver maple is not a particularly hard wood and I think that favors the scandi. If I was splitting a hard wood, I think that I would still favor a convex grind for less chance of binding.
Conclusion:
This experience has caused me reconsider my automatic bias toward convex grind knives. I acknowledge that the scandi grind offers a lot of benefits as a dedicated woodworking knife. It chews through wood with ease particularly on straight and perpendicular cuts. These findings reinforce the experience that I had last year when I got to try Nathan’s scandi K.E. Bushie. There is just something really fun to me about carving with a scandi Fiddleback. I can finally admit that I “need” one.
I am not going to convert my whole collection to scandi grinds, but I am ready to start a search for just one really nice old school heavily spalted & thick handled scandi Arete, KEB, Bushcrafter, or Hiking Buddy. Those don’t come up for sale very often, so I will have to offer up some nice trade bait to encourage some action. Look for a WTT ad in the Flea Market in the near future probably featuring the knives pictured below.
In closing, I again want to thank my friend Nathan for generously starting this pass around. So far you have won over both Michael and me to adding a similar scandi Fiddleback to our collection. I also have to acknowledge Tod (“hasco”) with influencing me also with the photos and write-ups of his great scandi Fiddleback collection. I am grateful to learn from the experience you guys share in this area.
I also want to thank my best buddy Jessie (a.k.a. “J-Dog”) for always keeping me company and supervising my knife activities. She’s a good girl even if she does insert herself in too many photos.
Phil
Bravo, Phil. An excellent write-up as usual. Though I do wish you concluded differently--I don't have any good "trade bait" to entice a knife out of someone's collection. 😉
I do hope the knee is back up to snuff.
Michael
Outstanding Phillip! Excellent pictures and tasks. It took quite some time to do both duties with each knife, take pictures and organize all of it along with your thoughts.
Thank you for sharing.
Once again you have provided us with an excellent post Phil. I really like the detailed comparison. I have come to many of the same conclusions about the differences between the scandi and convex Fiddlebacks. Thanks for the time and detail you put into this. The pictures where great, especially those containing Jesse.
I just wish you would not have reminded me how much I like the arete profile on a Fiddleback Friday when there was an arete in burlap waiting to be claimed. Now I have some more explaining to do.
Hello All.
I am the next in the chain.
There is no point in trying to recreate what Phil has already done so well.
As a result, I will be working with both a convex Arete and Thurin's knife.
Most of the wood that I work with will be dry. I will do some kindling prep, bark stripping, notching in larger stock.
I will also do some chores like breaking down boxes, slicing apples (I know, I know), breaking down stew meat and general garden chores (it's Feb, the garden is calling for those of us in south Texas).
I will see what I can do with pics, but I can offer not promises to be as comprehensive as Phil ; )
Phil does seem to be incredibly comprehensive in his posts. Maybe we can all come up with some sort of nickname for him that reflects this... 😉
Seriously though, you have no idea how eagerly I await each chapter in this unfolding story. Just do YOUR thing, man!
Michael
Thanks for the comprehensive (no pun intended) side by side review Phil. I hope the knee is healing well, and J-Dog is motivating you to get out on walks and start putting it to use.
Thanks Walt! I appreciate your kind words and acknowledgement for “my” review that I let Phil help me with.
Affectionately,
J-Dog
J-Dog (and Phil),
Thanks for this report! So much detail! And incredible pictures. As usual you provide a very comprehensive review with a wide range of tasks. I like the honesty in the review, discussing which grind did better in which tasks for example.
Thanks so much for spending the time testing and doing the write up.
I'm happy that it's J-Dog approved.
Well done post man. Damn it, now this post has me really wanting a convex Arete lol. Man I love the grind on the bolstered one you have.
+1. Phil's arête is one of my all time favorites.
Michael
I like knives that are simple, or even homely. I find that I have a hard time really using the pretty ones. That may explain why I like the Woodchuck so much!
That said, Thurin's Scandi Arete is a gorgeous knife that is a real user.
It was Nathan's Arête that sold me on the canvas OD. While I prefer earth tones 99% of the time! the OD never appealed me until I saw the organic way it aged with use. Ever since my turn with the knife, everything OD with white pinstripes has grabbed my eye.
Michael
