- Apr 19, 2012
THis is my first post to this Forum If my picture does not work I appologize. Any help would be appreciated.
I was lucky enough to get my hands on one of Andy's Scandi bushfingers. I had to give up two of my Blind horse scandi's to afford it but those can be had at any time from many locations. As for Andy's work, I have been following him for about 2 years and this was the first opurtunity I had to snag one. Andy as you all know is a great guy. Customer service is off the charts. I am waiting on a Ellsworth sheath for it now. Can't wait. I have been doing custom leather work for about 7 years now and have several unique designs, mostly concealed carry holsters. But that has never stoped me from buying other peoples leather. I appreciate the craftsmenship and labor that goes into the art.
To the title. Andy asked me to give my opinuon on his Scandi grind as it is my favorite and I have several hand made scandis to campare with.
First, I have seen both ends of the Scandi spectrum. from super thin, fine cutters to thicker more multi use grinds. To me the Scandi is the qunitisintal Bushcraft grind. It was invented for bushcraft and I have yet to find another grind that can beat it on it's home turf. This being said it is not a "Survival knife" grind. I would never use one of mine to open a can of beans or baton knotty wood. But for its intended job of aidding in preimative living skills, or Bushcrafting, it is right at home.
After some extensive use at home and on a weekend backpacking trip I have come to the conclusion that Andy knows what he is doing when it comes to Scandi grinds. My first Scandi was a BHK long tail. great little knife but the grind was so thin that it would chip easily in use. The second was my favoite, a BHK boat tail Scandi. it's grind was a bit thicker. It did not suffer from the chipping issue but did not take as keen an edge as a scandi usually can.
Andys Scandi grind lands right between these two. the grind is thin and I did experiance some inital micro chipping. This told me that the edge was properly hardend but I have to confess I was a little let down at first. I continued working with it as my experiance with some scandis was that with use the edge would ware down to a thicker more robust angle.
After the first sharpening, maybe 10 min worth, all the micro chipping was gone. It was after this that I took the bushfinger on a weekend BP trip. It saw use making fire, cutting 550 cord and some extensive carving to craft a ladel for my wife out of hard wood (not sure what kind but HARD). After all this I examined the edge very closely, looking for any chipping. NONE. whats more the little bugger was still popping hair off my leg using the entire length of the blade.
When I got home I desided to give it a proper sharpening to see just how sharp Andy's Sandi could get. Starting with 1000 grit and then going to 2000 and then to leather. I put a super flat edge on the blade that you could see yourself in. Spooky sharp but very, very thin. the edge chipped too easily. So I decided to allow the edge to convex just enough to gain the added strengh but not enough to take away from the "scandi experiance"
How I acomplished this was by placing the sand paper on top of a 1 inch thick foam pad and applied a little pressure during the sharpening proccess, same as above. It worked perfectly and what I was left with re-defined SHARP. This thing will shave you clean and you can't even feel the hair being cut. This thing is mystical Katana sharp and has just enough meat at the edge to prevent the chipping.
Over all Andy, Great job. Now that I have added the slight convexing, I would still consider it a Scandi grind, it is the best Scandi I have ever had If you wanted to improve the "out of the box performance" you might consider a little thicker grind, but if you did I would not have ended up with what I have now.
I am not even going to get into the fit and finish or handle ergos. Just one word, perfection!
I love it Andy Thanks again.
