Are you wanting a chisel grind or a standard grind? Either way the numbers are the same for an 11° Scandi.
11° grind @ .103 thickness = .530 grind height
I thought I would add how you solve this.
Grind height = Adjacent on right angle
Blade thickness = Hypotenuse on right angle
So Adjacent = Hypotenuse / tan(°)
Adjacent = .103 / tan11°
Adjacent= .103/.1944
Adjacent= .52983
Grind height = .530
So I hope this helps others calculate there grind height. The above numbers are for 11° but if you are after a different angle then replace the 11 with your number.
Sorry that was a miss print, I ment opposite
The past tense of mean is meant and misprint is one word.
Just busting JT's balls with my Saturday night, had too many drinks, wishing I was at blade sense of humor.Likely autocorrect...with math skills like that I think he can probably spell...just saying
I'm only 6 hours away. I regret not leaving out yesterday.I hear that. I went last year for the first time. I didn't even see close to everything I wanted to. Maybe next year...
Sadly, too many of todays youth want all the numbers feed to them, an "app" for determining angles and such, and jigs to do the work for them. This leaves them helpless to do it in their head or figure it out themselves.
I'm 51 years young and use a jig and the blade angle grind chart.
