I can not resist but give my two cents here and hope that "kedavis" benefits somehow. A scandi edge-bevel is just the same as a "regular" edge-bevel, just put on thicker "stock". Imagine you have a grinding jig, set at 15 degrees per side. Now you take a 3mm (it could be 5/32, 3/16 etc.) stock blade and grind it to an edge, symmetrical on both side. Now you take a 0.6 mm "stock" (resembling a blade with a secondary flat grind at about 4-7 degrees or so and about 0.02 before sharpening at the future apex) and do the same thing. The only difference between those edge-bevels is the surface area of the bevel. After a fraction of a millimetre the 0.6 mm stock bevel reaches the it's stock (the secondary grind) and goes up to the spine on a much more acute angle of often 4-7 degrees or so. The 3 mm stock bevel continues at the same 15 degree angle until it reaches it's stock (the "secondary" grind which in this case is the flat stock of 3 mm) and then goes flat to the spine. So until those two edge-bevels reach their individual stock, the geometry/thickness/strength is exactly the same! But - right beyond that point, the 3 mm stock edge-bevel continues to get thicker at the 15 degree angle, the 0.6 mm stock edge-bevel however continues only very slightly to get thicker at the angle of the secondary grind that is. So the bottom line is, the scandi bevel (3 mm stock edge-bevel) is actually stronger/thicker. The delicate thing of a scandi grind is not! the character of the grind itself, it is the unusual low edge angle of often less than 12 degrees per side. This is all different of course for convex grinds. The only area that a scandi excels in my opinion is on wood if it is being used like a chisel since the large bevel area serves you like a plane (plain?). Also, the tip is usually quite sturdy an may be stronger for some drilling tasks. As mentioned above, it may also help pushing wood apart during batoning and gets the very apex off the wood contact faster/earlier resulting in better edge retention, however in real life I have not noticed a difference compared to other grinds.
I could have a 1/4 inch thick 3V chopper with a 20 degree per side scandi bevel on it, and it would be stronger than a flat ground chopper that is 1 mm thick before edge, has a nice secondary grind to spine and a final edge bevel of the same 20 dps. Of course, a 1/4 stock scandi does not make any sense since the cutting/chopping geometry would be awful.
I agree to above that a slight convex makes a better woods knife (no biting in, no bouncing off) but once you start sharpening your scandi by hand, it will be a slight convex over time anyway. I believe, although I have not used a Condor scandivex, that that convex geometry might be to obtuse, similar to the Bark River Bushcrafter and it's scandi-vex. Too obtuse and the edge has the tendency to "bounce off" the wood.
